- Mute
08-29-2023
02:28 PM
(Last edited
09-04-2023
07:02 AM
by
SamsungJecca
) in
Hello
I have an older Samsung UN28M4500 TV. Serial #:<HIDDEN>. I had been using my coaxial ANT IN port for my AT&T Receiver input, but I now need that for an antenna input. I am trying to use a 4K 60Hz HDMI cable from the AT&T Receiver to HDMI1 on the TV. I get a good quality picture but it's too small. Have tried everything that I can find using the e-manual. It can't find any newer Software version other than 1310. Did a Picture Reset. Soft Reset of the TV and all the Picture Size settings that I can find. Not as many options as more recent models. I reset the AT&T Receiver and tried all its resolution options. Any ideas of what I may be able to do to fix this?
Solved! Go to Solution.
- Mute
09-05-2023 02:20 PM in
4K, 8K and Other TVsHello! Thank you for reaching out! I see how this can be a cause for concern with your TV not having the correct aspect ratio. I would recommend first seeing if there is a setting on your cable box to reduce the resolution to 1080p if it does not do so already as your TV is a 1080p screen and can not properly support 4k. If it does not, I would also recommend reaching out to your cable provider to help with the picture settings.
Something else that you can also try is to zoom in by going to settings> Picture > Picture Size and select from there fit to screen.
If this does not help then the only other thing I can think of is to make sure that it happens with every channel, It has been a while since I personally used cable but from what I remember some channels will be HD channels and others will be standard and will have different aspect ratios.
If nothing else you can also call in direclty at 1 (800) 726-7864 and ask for our remote management team to help also.
- Mute
- Mute
09-03-2023
11:21 AM
(Last edited
09-07-2023
01:36 PM
by
SamsungCaleb
) in
Hello
I have an older Samsung UN28M4500 TV. Serial #: <hidden>. I had been using my coaxial ANT IN port for my AT&T Receiver input, but I now need that for an antenna input. I am trying to use a 4K 60Hz HDMI cable from the AT&T Receiver to HDMI1 on the TV. I get a good quality picture but it's too small. Have tried everything that I can find using the e-manual. It can't find any newer Software version other than 1310. Did a Picture Reset. Soft Reset of the TV and all the Picture Size settings that I can find. Not as many options as more recent models. I reset the AT&T Receiver and tried all its resolution options. Any ideas of what I may be able to do to fix this?
