- Mute
09-10-2022
11:15 AM
(Last edited
02-15-2023
07:44 AM
by
SamsungJecca
) in
Just got a Samsung TV model UN43TU7000FXZA. Trying to get my remote to turn the my Spectrum cable box on. I have it in the correct HDMI port. Any info ON how to do this. The only way to turn the cable box on is by using my old remote.
Thanks
Roy
Solved! Go to Solution.
- Mute
09-10-2022 12:42 PM in
4K, 8K and Other TVs1. TV may not support CEC.
2. Cable box may not support CEC.
3. If using a splitter or something else, you may be stripping those commands out.
In the TV settings, go to inputs, and it should prompt you to set up a new device. Follow instructions there. If it fails to autoconfigure with CEC, you may need to contact Spectrum.
- Mute
- Mute
09-13-2022 03:43 AM in
4K, 8K and Other TVsHave a new Samsung tv model 43TU7000FXZA. See it up with a Spectrum cable box. Cable box is a few weeks old, and worked with the old tv. With my new tv the remote will turn tv and box on, but won't turn the cable box off.
Thanks for any help.
- Mute
09-13-2022 05:45 AM in
4K, 8K and Other TVs- Mark as New
- Mute
09-13-2022 06:00 AM in
4K, 8K and Other TVsI did but the problem I have now is the remote turns both tv and cable box on , but won't turn cable box off.
