QN65s95B not going to last used input on power on.
(Topic created: 09-02-2022 02:04 PM)
user7HPfPvVbtZ
4K, 8K and Other TVs
Just got this TV and love it.  Only issue is that when I power it back on it does not go to the last input used.  On the settings it says if I turn off the smart hub it should go back to the last input used upon power on.  It’s turning on, then quickly switching to another HDMI input and saying the device is off.
The last input was a Directv stream device.  It does turn on.  The TV just switches away from it.  Any tips?  Thanks in advance.
Samsung_Moderator
Hello! I understand how this can be a cause for some concern with this occurring. Just want to make sure that this is occurring even if the external device is turned on first. Also, make sure to have it enabled if it was possibly turned off you can do that by the following:
  1. Open menu
  2. select ‘Settings’.
  3. Choose ‘General’.
  4. Select ‘Start setup’.
After that, the next step you can try is to factory reset the TV to solve this issue.
You can also reach out directly at 1 (800) 726-7864 and ask for our remote management to also get this looked into further.
1 Reply
Samsung_Moderator
  1. Open menu
