Simultaneous Bluetooth and tv audio
(Topic created: 09-07-2022 04:37 PM)
LSUMECH
4K, 8K and Other TVs
Hi
I have a UN82RU8000FXZA. I tried to set the simultaneous Bluetooth & TV audio. I went to the settings general and accessibility, but the multi-output audio is grayed out. Is there a way to enable it?
Samsung_Moderator
Hello! I understand how this can be frustrating with multi-audi not working. You can try the following steps.
1. Pair your device first
2. Make sure you are on the home screen
3. Select Menu
4. Select System
5. Select Accessibility
From there you should be able to select the option for multi-audio.
If this does not help you can call in directly and speak with our smart things department at 1 (800) 726-7864.
1 Reply
Samsung_Moderator
3. Select Menu
4. Select System
