- Mute
‎04-15-2022
03:56 PM
(Last edited
‎04-19-2022
01:21 PM
by
SamsungCaleb
) in
Hello,
I have a QN9DA and a Denon AVR-S750H. I have a cable box connected through the receiver via HDMI. If watching through cable box and using apps through the box the audio all works. If I try and use any of the apps on the TV (Netflix, etc) then I get the video from the app but still get the audio from whatever channel was on the cable box. I'm lost. Any advice would be appreciated !
Solved! Go to Solution.
- Mute
‎04-17-2022 07:34 AM in
4K, 8K and Other TVsI can definitely understand how frustrating this may be. I recommend plugging the tv into the receiver, not the cable box. This way anything connected to your tv will have the audio pass through.
- Mute
‎04-15-2022 11:59 PM in
- Mute
