- Mute
‎11-28-2022 12:07 PM in
4K, 8K and Other TVsI just purchased a 65" Samsung TV UN65TU700DFXZA 7 Series
On Page 18 of the User Manual, it states:
"To connect a LAN Cable, use a CAT 7 (*STP type) cable for the connection."
*Shielded Twisted Pair
I have Fiber Optic Internet Service (80 Mbps) & 1 of 2 Apple Airport Extreme Routers in the house is within 3 feet of the TV.
The TV is connected to that Router with a 6' CAT 6 cable.
The Fiber Optic Service comes into my attic on a CAT 5e (?) Cable
So, I am not sure that a CAT 7 LAN cable would provide any benefit at all.
All comments are appreciated
Model UN65TU700DFXZA
- Mute
‎11-28-2022 12:11 PM in
4K, 8K and Other TVs- Mark as New
- Mute
‎11-29-2022 06:55 PM in
4K, 8K and Other TVsThe Cat 7 or Cat 6 cable is to connect the TV to the internet.
No matter which cable I use should not have anything to do with the picture quality.
Or. am I missing something here?
- Mute
‎11-29-2022 06:59 AM in
4K, 8K and Other TVsDoes anyone know why Samsung would specifically recommend a CAT 7 cable for this & similar TVs?
I would assume that the internet service into most homes would be CAT 6 or lower.
I just don't see how adding a CAT 7 cable at the end of that internet service (between the Router & the TV) would add any benefit - unless the cables before it are all also CAT 7
And no one would replace all of their existing cables just because a TV requires CAT 7
- Mute
‎11-29-2022 01:48 PM in
4K, 8K and Other TVsThe only thing I can think of is that they're assuming in-wall runs very close to AC power lines and the extra shielding might be beneficial. CAT 5e is sufficient for gigabit and 2.5G and once again, these TVs all use stone age adapters so a ripped up CAT5e cable with exposed copper probably won't show any speed drop.
