red light flashes and tv won't turn on
(Topic created: 08-01-2019 08:42 AM)
userrhz4W5bDrA
4K, 8K and Other TVs
I have this tv and it will not turn on. I have done the things the posts have said to do as a trouble shoot. It has always been plugged into the wall directly.
What else should be tried? model un49mu6500fxza  version fa01   #<Hidden>
Suggestions?
JUMP TO SOLUTION
userhu5azEWL64
I am having this same issue rigth now with my tv which is a couple of years old. Wondering if it is that it needs to be replaced or if it can be fixed. I tried the steps listeed on the threads but nothing changed.
SamsungRei
@userhu5azEWL64 Thanks for reaching out! Please send a private message with the full model code and the serial number, along with the steps you have tried so I may look into this further. http://bit.ly/2XERsky
userCESruNvN0Z
I was wonder did you ever get it fixed and how much did it cost because I'm have the same exact problem
user5pmB84I7Pi
Hi, im having the same issue where tv won't turn on, red flashing light from under samsung logo, ive plugged in to wall socket, what is next?
userI2j5oZDmef
I am having the same issues with my 60 inch flat screen model un60j6200af version ea03.
What kind of cost am I looking at to repair.
JRS44
MY TV HAS DONE THE SAME THING AND STILL WON'T TURN ON. IT WAS UNDER WARRANTY AND WANT TO KNOW IF DUE TO COVID THE WARRANTY'S WERE EXTENDED IN SOME FASHION? IT NEEDS REPAIRED NON OF THE TRICKS TO TRY TO FIX IT WORKS.
