userCCGejNOLFV
3D LED UN46d6900wfxza
JUMP TO SOLUTION
Television just starting turning itself on and off. Are there any suggestions on resetting it or getting it repaired?
1 SOLUTION
Re: 3D LED UN46d6900wfxza
JUMP TO SOLUTION
Is the television plugged into an outlet directly or is it plugged into a surge protector? If it's turning off an on while plugged into an outlet directly, service would be needed. You can find an authorized service center here: http://www.samsung.com/us/support/service/location Or, if you like, you can send a private message with the full model code and serial number and I can look into what options are available. http://bit.ly/2XERsky
1 REPLY 1
JUMP TO SOLUTION
