75” Q90T optical audio keeps switching to TV audio
(Topic created on: 4/16/21 7:20 PM)
techra
4k, 8k and Other TVs
Hi
I recently purchased this tv few days ago and I have it connected to a Samsung soundbar over optical cable. Randomly when I start the tv the audio switches to tv audio and I have to go to tv settings to switch it back to optical. I have tried turning off intelligent mode (don’t believe it has anything to do with switching audio) also have tried to leave the sound bar always on. But it keeps on happening randomly.
any suggestion to fix the audio output to optical.
thanks
SamsungCaleb
I'm sorry to hear that, does this occur when using HDMI? Also, have you made sure that anynet+ is turned on?
techra
No, there is nothing connected over HDMI. The soundbar is connected through optical cable. Anynet+ is on, but does that have any impact on optical cable? I thought it was for only for HDMI-CEC.
thanks
SamsungCaleb
My apologies for not clarifying have you tried using HDMI to see if this issue still occurs and if soo when anynet+ is turned on does this still occur?
