Highlighted
Bluetooth audio doesn’t work
Hi,
I connected my bluetooth headphones to my samsung tv. It shows headphones connected but the audio is still played through the TV speaker. It used to played through my Bluetooth headphones, but it stops working today. Dont know why. Need help.
4 REPLIES 4
Highlighted
Re: Bluetooth audio doesn’t work
My Xbox will do that if I don't change the audio setting from TV speaker to head phones. Hopefully you'll find something like that in the TV settings.
Highlighted
Re: Re: Bluetooth audio doesn’t work
sorry if this isn't much help thought I should try
Highlighted
Could you please provide the model number for the television?
Highlighted
My Samsung TV was doing the same thing. The headphones worked fine for sometime. One day I wanted to use them but the TV speaker was the only working sound device. I then realized that my Samsung cellphone was near me with the bluetooth option turned on. I turned it off on the cellphone and then the TV connected to the headphones as usual.
Hope this solves your problem also.
The headphones were connecting to my cellphone and not the TV.
