Can't control cisco 9865hdc and audio sync issues
(Topic created: 07-11-2021 08:54 AM)
userlUgtj2u38p
4k, 8k and Other TVs
Got this tv two weeks ago (QN90A). Yesterday I updated to the latest software (1506) because the audio was skipping every 30 minutes or so. Now, I am having two problems. The audio is constantly getting out of sync when watching TV (cable). On my Roku it is also getting out if sync but seems to fix itself when I pause it for a second. This fix does not work on cable.
To try and fix the issue with the audio I swapped out the HDMI cable, in doing this, the TV is making me reset up the cable box. The TV will now not recognize the cable box (cisco 9865HDC). I have tried resetting everything, unplugging, putting the cable box directly in front of the sensor on the TV. I've tried every suggestion I can find. Nothing works.
This is an $1800 TV. It is unacceptable for it to have both syncing issues and remote issues. Is Samsung ever going to address and fix these issues??? And before we start blaming the cable box, I could control it just fine until I updated the samsung software, so this is NOT a cable box issue. The syncing problem is also clearly not a cable box issue as it is also happening with Roku which does not go through the cable box.
SamsungLarry
Have you attempted a factory reset of the unit? Also, ensure that the unit is plugged directly into a wall socket. I don't know how, but this fixes a lot of issues with tv's for some reason.
userlUgtj2u38p
Yes on the factory reset but no on the directly to the wall. I live in an apartment and the power flickers quite often so I'm not comfortable plugging this pricey of TV into the wall.
SamsungLarry
I recommend calling into 1-800-SAMSUNG. The remote management team can remote into your tv to attempt a fix this way.
userlUgtj2u38p
Ok thanks!
Please update your TV to version 1560.5 to resolve the lip sync issue. You'll need to first download the file, unzip it, load it to a USB and connect to your TV to do the update.
Download link here: https://www.samsung.com/us/support/downloads/?model=N0054535
