userFxmhmLt5R5
Flashing red light, mute symbol on tv and remote won’t work
My Samsung has a red light that keeps rapidly blinking, the mute symbol is flashing on the tv and the remote won't work. I can't get it to hard reset and I can't use the tv itself to hard reset. Every time I go in to the menus it closes quickly. I took the remote batteries out and it's still happening!
5 REPLIES 5
Re: Flashing red light, mute symbol on tv and remote won’t work
We are sorry to hear about this. Please send the model and serial numbers to this PM Link.
userp3eKQpp2C8
I'm having this exact same issue. Can you help?
userp3eKQpp2C8
Did you get a fix for this?
Thank you for reaching out! Could you send me a private message with your full model and serial number?
userYuQdHOjXQI
I have the EXACT same problem, please help.
