HDMI settings a reset after cable unplugged
(Topic created on: 12/15/20 5:01 AM)
user7UZiYn6wt6
4k, 8k and Other TVs
Each time HDMI cable is disconnected, TV resets it's input settings, in particular "input signal plus" and "game mode". When I want to connect a laptop to my TV, I have to go to the settings and enable "input signal plus" or otherwise it will limit refresh rate to 30Hz at 4k resolution. Then I can connect HDMI cable, go to the settings again to enable "game mode" or otherwise picture on the screen will lag.  As soon as I disconnect HDMI cable those settings are lost.
I bought UE65TU8000UXUA with intention to use it mainly as a big screen computer monitor for my laptop for the times when I am working from home and the fact that I need to repeat the procedure described above several times a day is super annoying. By using method described here https://www.samsung.com/us/support/troubleshooting/TSG01111222/#turn-off-automatic-hdmi-switching-wi... (Mute, Vol Down, Ch Down, Mute) I was able to disable automatic detection of HDMI devices which helped a lot, but the fact that it fails to remember it's settings totally ruins the user experience.
Please give me a way to make those settings to persist across HDMI cable disconnects.
userNFRUqPYmxT
6 9
SamsungLou
Thank you for this info! As this is a non-US model and support for these models is very limited, please seek support for your area. You can do so here: https://www.samsung.com/us/common/visitcountrysite.html.
user7UZiYn6wt6
Thank you for your reply!
Unfortunately when I follow your link and select Ukraine, it starts redirecting me until I get an error 414 - Request-URI Too Long.
I do not mind changing firmware to something that have more support (loosing localized features is totally fine for me), if only it would help to resolve the issue.
SamsungLou
Sorry, there appears to be an issue with their site. You can call them directly at 0-800-502-000.
