userxJfPFBBLlW
Re: Issues with WiFI connection - Smart TV
JUMP TO SOLUTION
I am also having issue with wifi connection.
userVZF0y9DDAz
JUMP TO SOLUTION
I have the same problem. The TV cannot find any WiFi networks. I get the screen where it searches for wifi networks. I click on Start, then it goes right back to the screen where I can only enter start or cancell. I have model UN55ES8000FXZY. My WIFI works on all other devices (Iphone, tablets, etc). I used to be able to have Wifi on this TV, but haven't had it for a long time. The software version is T-ECPAKUC-10570.
userVZF0y9DDAz
JUMP TO SOLUTION
I just updated my firmware via USB card. Still did not make a difference My TV still cannot detect any wifi networks. So, I still cannot use apps on the samsung hub.  The next TV we get will NOT be a samsung.
JUMP TO SOLUTION
Have you completed all of the troubleshooting in this article? http://www.samsung.com/us/support/troubleshooting/TSG01111014/
userenTlZi5a3H
JUMP TO SOLUTION
Hello. Please am having the same issues with my Samsung.
Model : UE55NU7300
Serial No : 0DWQ3HNK702902A
Software Version: T-KTM2LDEUC-1202.3
userXBsokDSpAA
JUMP TO SOLUTION
so i'm i,  I can't  connect to the wireless network.  and i donnow what's the problem!!
________________________________
bluestacks textnow  photomath
uservugDcf0tXq
JUMP TO SOLUTION
I am having a similar problem, I have had no issues connecting prior but for the past 4 days I cannot get the tv to connect with my Wi-Fi, I have no issues with the Wi-Fi with all my other connected devices, its just the Samsung tv that has problems connecting.  I believe I am up to date with the software updates. I have tried all the reboot, restart, manual dns, etc nothing worked . I need help please.  Here is my tv info;
Model: UN55MU6290
Software version: T-KTMAKUC-1240.4
Sub-micom version: T-KTMATSCL-3.0.1
JUMP TO SOLUTION
We are sorry to hear about this. Please send a private message to this link with your serial number, and we will look in to this.
userBzPdDWSMBh
JUMP TO SOLUTION
Hi
i have an issue connecting to my WiFi
the mode code of my tv is Ue40j5270 and the current version is 1129.1
please help
JUMP TO SOLUTION
We can only support US products. Please contact Samsung Support in your region: http://bit.ly/lBD2zm
