usereTge2YS8hA
LED backlight flickering issue on UN65KU6290F
JUMP TO SOLUTION
I purchased UN65KU6290F at bestbuy less than 2 years ago, and recently noticed that backlight was flickering intermittently at the bottom right around the Netflix tile in the picture below.
Now the backlight is gone and the area is dark as you see the picture below (circled in blue).
While I test the screen, I also noticed that backlight wasn't uniform. specifically top middle section (between 244 and 245) and 4 corners of the screen, even though I didn't see those sections were flickering.
My questions are
1. Do you think this kind of uniformity is normal or backlights in those areas are dead?
2. If it's not normal, is it repairable? If so, how much does it cost?
Thanks in advance.
1 SOLUTION
Re: LED backlight flickering issue on UN65KU6290F
JUMP TO SOLUTION
We are sorry to hear about this. Please send the serial number to this PM Link.
2 REPLIES 2
JUMP TO SOLUTION
usereTge2YS8hA
JUMP TO SOLUTION
@SamsungLou PM sent.
