Light bleeding through UN65JS8500 screen
(Topic created on: 1/16/19 12:54 PM)
user0tC7rduqfk
4k, 8k and Other TVs
Hello,
I purchased a UN65J8500 3 years ago and just recently, within the last 2 months, I started noticing what looks to be light spots shinning through the panel. These light spots are especially noticeable on solid colors.
I've posted a couple of images of what it looks like:
https://imgur.com/a/l7eRIUK
Is this something that I can fix or is this panel not worth saving?
Any suggestions would be greatly appreciated.
cheers,
devin
JUMP TO SOLUTION
usery3FxxfjJ9K
Cosmic Ray
Unrepairable junk.  Physical damage from heat.  Samsung does not stand behind their products.
VKtravel
I am having the SAME EXACT issue with mine.  I didn't even realize it was ot until I touched it just now.  Please let me know how to repair this issue.
usery3FxxfjJ9K
Cosmic Ray
Nothing can be done.  Physical damage from heat.  Avoid Samsung.
usery3FxxfjJ9K
Cosmic Ray
Unrepairable junk.  Physical damage due to heat.  Samsung does not stand behind their products.  AVOID.
Benchap
Please Help!
I have the same/similar issue on my UN55JS9000:
  1. It displays the vertical light bleed in 2D/3D mode on the left side
  2. It displays vertical shaded (overlap) bars in 3D mode that move/change depending on what's being displayed (both via HDMI and streaming - so not a connection issue)
Light Bleed:
Left Side Light BleedLeft Side Light Bleed
Strange 'moving' vertical bars in 3D Mode:
Left Side Bar AloneLeft Side Bar AloneBars on Both SidesBars on Both SidesRight side bar alone w/light bleed on leftRight side bar alone w/light bleed on left
SamsungTam
I would be happy to look into this for you. Please send us a private message to the link.
User-Q7MuE8H
Same issue with mine as well what is the solution to this
userhUIpBPH8wm
I've been having this issue (bleeding, overheating) for a long time and just randomly stumbled upon this post while looking for replacement parts (I refuse to throw away such a expensive TV). It seems like the moderators here (@SamsungLou) are being responsive and would like to get in touch with them and figure out what are my options.
SamsungAl
@userhUIpBPH8wm Thank you for reaching out! :) Could you send me your full model code, serial number and some photos of your TV where you are having the light bleeding and overheating via private message?
http://bit.ly/2sSxapD
usery3FxxfjJ9K
Cosmic Ray
As you probably found out Samsung does not stand behind their products.  Occasionally they throw a bone to one of us customers but for the most part they do nothing.  These TV's are unrepairable due to heat damage.  AVOID Samsung.   JUNK!!
