- Mute
‎08-12-2021 05:11 AM in
4K, 8K and Other TVshello I am having the same problem that I know mentioned in this topic, does anyone know if there is any solution apart from changing the motherboard of the TV ???
Solved! Go to Solution.
- Mute
‎08-13-2021 02:56 PM in
4K, 8K and Other TVsHey I am so sorry you are having the same problem as prior, the next step recommended would be for you to give us a call and request to speak with our remote management department directly. Please let me know if I can assist you further by contacting me here: https://bit.ly/3lVQyQ2.
- Mute
- Mute
‎10-10-2021 09:16 PM in
4K, 8K and Other TVsHey just wondering if you managed to find a solution for this? I'm having the same problem with the same TV 😞
