Highlighted
“ Q70T 85 inch” Sound sensor notifications won’t stop popping up!!
1 REPLY 1
Highlighted
Cosmic Ray
Re: “ Q70T 85 inch” Sound sensor notifications won’t stop popping up!!
For the time being you have to switch the sound sensor off. At the bottom of the TV where the Samsung logo is there should be a small switch you can slide to the off position on the bottom (that is where it's located on my Q80T anyway). So far Samsung hasn't even acknowledged there's an issue to my knowledge... which is unfortunate.
