Q90t not running HDR on PS5 in 4k/120???
(Topic created on: 1/11/21 11:36 AM)
chuckh03
4k, 8k and Other TVs
I copied this from another consumer, trying to find out if this is a hardware issue or a software update before my return period is over.....SAMSUNG PLEASE RESPOND TO THIS FOR ALL INQUIRING USERS!!!!!!!!
I've seen a reoccurring problem with new ps5 owners and the Q90T. The Q90T is able to output 4k 120hz with no problems. For some reason the Q90T can't output HDR along with with 4k 120hz signal. I know the PS5 is maxed out at 4:2:2 for 4k 120hz, is there any way the Q90T can play 4:2:2 HDR with 4k 120hz?
SamsungCaleb
I'm sorry to hear that, so that I may look further into this can I have the TV's full model number?
chuckh03
chuckh03
QN55Q90TAFXZA
SamsungCaleb
After looking through the user manual there is nothing about it not be able to support HDR and 4K 120Hz but also keep in mind that there can be limitations on the console that is causing this issue to occur, for more information about the refresh rates please look at the user manual on page 103 and down: https://downloadcenter.samsung.com/content/UM/202011/20201116112509205/KT2ATSCT-2.1.5_EM_KANTS_USA_E...
SamsungCaleb
Are you using the cable included with the PS5 console or an Ultra High-Speed Cable that is rated for 4K 120Hz output?
Is the PS5 console directly connected to the TV by HDMI, or to a receiver or other piece of intermediary equipment that could be affecting the signal?
Is the PS5 Screen and Video > Video Output > Resolution set to Auto or 2160p?
Is the PS5 Screen and Video > Video Output > 4K Video Transfer Rate set to Auto?
And are you making sure the PS5 Is plugged into port 4?
Also in the settings make sure that HDMI mode is set to 2.1.
daire_mccormack
Hi, as chuckh03 has said this is not an issue with a specific TV or even specific model but with all of Samsungs 2020 OLED TVs. None of them are currently capable of outputting 4k 120hz with HDR with the Playstation 5, while other TVs (such as the LG CX) can do this. This has been reported on multiple forums and through various news channels so is a known issue and will only be solved with a firmeware update.
Can you please investiate let us know if Samsung is working on this problem and expects it to be resolved?
chuckh03
Thanks again Daire, see comment below Caleb (shldve simply replied)
chuckh03
chuckh03
See below...the tv is capable I'm aware, there's an issue with it on the PS5 only but not a console issue bc it doesn't have the issue on the LG CX for example so has to be the Samsung line
