Highlighted
Remote not working and red light is flashing with UN55RU800DF
Hi,
Im having the same issues with the remote not working that I’ve read from previous posts. Tried everything - replacing batteries  - pairing with the back and play button with no luck. Keeps telling me not available. TV is only 6 months old. This shouldn’t be happening this early. What next?
UN55RU800DF
7 REPLIES 7
Highlighted
Re: Remote not working and red light is flashing with UN55RU800DF
I would recommend factory resetting the TV you can do that by navigating to Settings and then General. Select Reset. Enter your PIN (0000 is the default) and then select Reset. To complete the reset, select OK. Your TV will restart automatically. If these steps don't match your TV, navigate to Settings > Support > Self Diagnosis, and Reset will be located in that menu.
Highlighted
I can’t get to settings. When pressing back or home button The remote just flashes and the TV reads not available.
Highlighted
Could you send me a private message with the full model and serial number?
http://bit.ly/2sSxapD
Highlighted
This has happend on both of my TVs... my kids get the remotes, push the buttons too hard and they "stick". The flashing red light is a constant signal from the remote. Check all the buttons and see if the helps.
Highlighted
Sorry, I forgot to include, a simple test to see if it is the remote. Hold your hand over or block the IR sensor on the front of the remote, if the blinking red light stops, probably a stuck button. That's how I figured mine out.
Highlighted
I have the same problem. 6 month old tv and remote red light flashes. The on/off button works but nothing else. I tried to pair the remote but now I get a message on the tv that says "not available". I don't know how to factory reset the tv since the remote does not work.
Highlighted
I'm having the same problem - started yesterday and also tried all the suggested ways to correct it. How did you fix it?
