userUUrmF8qAfl
Re: Samsung LED Smart TV keeps turning off and on
JUMP TO SOLUTION
What was the video? I am having this same problem now.
useruRenNm2lbK
JUMP TO SOLUTION
I think it something to do with any wireless connection the TV has to another device.
usereoArU76Y09
JUMP TO SOLUTION
My tv started the power off cycle today, 3-4 years old, and I have found the network to be suspect.
Looking at possible problems, like auto shut off settings, I wanted to look into software updates that might be available.  Since i have been using another, non samsung, device to connect i had to try and set up the network connection.  It failed.  2-3 times in a row i tried to access the network set up menu and the tv controls froze up until the on/off cycle triggered (it is happening every 4-6 minutes).  It is also worth mentioning that the display did not freeze, the cycling images of a screen saver kept being updated without a hitch, just the tv setting menu disapeared when ì selected the network setup option and the remote became unresponsive.
Attn:  Samsung staff.  You need to post something that the public can see FAST.  This thread looks very bad but a simple public response, even a we don t know, would go a long way to salvaging what seems to be a growing problem.
JessikaZ
JUMP TO SOLUTION
We started having the same issue with our TV several months ago and it’s extremely frustrating! Sometimes the TV won’t even turn on before it begins the cycle, other times we could be in the middle of watching and suddenly it will turn off and begin the constant “clicking” like it’s trying to turn back on.
We’ve tried unplugging for several minutes- nothing. By the looks of it, Samsung doesn’t really seem to care that this is a huge issue!
userCit1jxHQu9
JUMP TO SOLUTION
This appears to be a remote problem and by removing the batteries from the original Samsung remote and using a universal remote solved our issue. Hope this helps someone else!
JUMP TO SOLUTION
We appreciate the input!
userdaTRXLBLvI
JUMP TO SOLUTION
My 75 inch 4K Samsung just powers off and on while watching program.  I have called Samsung several times about this with no solution.  My TV was purchased in April of 2018.  I also called my cable provider and they are telling me that it is a problem in the TV itself, nothing else.  They also referred me to this post as many people are having this
same problem.
He said it was not the cable box because it does not go off when the TV does.
JUMP TO SOLUTION
@userdaTRXLBLvI, we would be happy to look into this for you. Please send us the model number and the serial number to the link.
userWcuueJDNzN
JUMP TO SOLUTION
I solved by disconnecting the internet connection both wifi and eternet
jace1113
JUMP TO SOLUTION
Yes! Count me in because not even the technician that I have insurance with the tv doesn’t know what’s the problem. He kept saying that is something wrong with mother board.
