Re: UN70KU6300F TV Turns Off and On
JUMP TO SOLUTION
This type of issue will need to be addressed by having the unit serviced. You can use the following link to find a list of service centers near you that can do the repair: http://www.samsung.com/us/support/service/location
userL9xg2aBcAa
JUMP TO SOLUTION
I would love to use that page to find a service provider. However when I put in my address it says, "This page can't load Google Maps correctly."
I have tried in both browsers: chrome and Brave. Not sure what to do now.
https://www.samsung.com/us/support/service/locations/?product=N0002210
JUMP TO SOLUTION
Can you please provide the zip code?
userL9xg2aBcAa
JUMP TO SOLUTION
Can you tell me how to find a service provider if the map is broken on the following link?
I tried Brave, Chrome, IE. None work.
JUMP TO SOLUTION
There are two service centers for this area.
PLAZA ELECTRONICS & APPLIANCES
1518 DECATUR PIKE
Athens, TN
423-745-0502
USSI - UNITED SERVICE SOURCE, INC.
9145 Ellis Road
Melbourne, FL
321-953-5294
USSI is a national center that works with local repair providers to cover specific areas.
JUMP TO SOLUTION
userL9xg2aBcAa
JUMP TO SOLUTION
37774
userbtZn4Ddqc4
Samsung LED Smart TV keeps turning off and on (UN75F6300AF)
JUMP TO SOLUTION
Samsung LED Smart TV keeps turning off and on.   Model Code: UN75F6300AFXZA  Version No: UH02    Please provide the solution.
Thanks, Pradeep
user1OwedEu5W4
Re: Samsung LED Smart TV keeps turning off and on (UN75F6300AF)
JUMP TO SOLUTION
I'm having same issue started yesterday my TV is a  un 55mu6290
JUMP TO SOLUTION
It is possible this is a software concern. To check on this, try to power reset the device by unplugging it for a few minutes and plugging back up. After that, you can try to check if the TV has the latest update installed.
