user9oHsNVBdCf
Re: Samsung LED Smart TV keeps turning off and on
JUMP TO SOLUTION
I had the same issue last night and Samsung couldn’t do anything to help it’s such frustrating and I will recommend anyone to never ever purchased Samsung product
MitziC
JUMP TO SOLUTION
Having the same issue as of yesterday during my sons 4th birthday party! TV continuously power cycles, tries to load the smarthub menu but never fully does, then cuts off. Just does this repeatedly after we tried to change the video source using the remote that came with the tv. This is really ridiculous for a costly tv from a "reputable" manufacturer. I have a UN55H6400AF. Someone please tell me there is something we can do other than repair at a cost of over 1K...RIDICULOUS
userPK2JlAGBQC
JUMP TO SOLUTION
Repair at own cost is the only solution when the company offers a 1 year (LOL) warranty when tehy knowingly use circuits that are lasting an average of 12-16 months. Never buy Samsung again.
MitziC
JUMP TO SOLUTION
NEVER! and will be telling everyone I know about this.
userJMHqLgyVsg
JUMP TO SOLUTION
After scrolling thru 7 pages of similar posts, I discovered there is no solution and the "Solved" tag is because Samsung posted a note to send them the unit and serial numbers.  My TV is less than 2 years old and this failure is unacceptable although now I get to buy the 4K TV I've wanted all along.  It will NOT be a Sumsung TV nor will I ever purchase another Sumsung product.
LuckyCharm253
JUMP TO SOLUTION
Did you try this solution, which I posted just the other day? Fixed mine.
user2pjx2O6hvz
JUMP TO SOLUTION
I have the same issue.  Read somewhere to change the batteries in the remote.  That worked!  It stopped turning off and on.
userwbFZ6M9UhI
JUMP TO SOLUTION
I am having the same problem with my UHD Samsung. It keeps turning off and on by itself. I tried unplugging it and it still has a mind of itis own. We have six Samsung TV's and they all work perfectly. The picture on the problem set is awesome when it works.
The model Number is UN40HU6950FXZA. Serial Number <Edit>
The TV is used in the guest bedroom and has been used very little. We have five others that have performed without flaw for years. This was a special purchase that we splurged for and now we wonder if UHD was the way to go.
We learned that there was a class action suit that Samsung supported by replacing a capacitor. Can I bring my TV back to Best Buy to have this service performed?
Please let me know as soon as possible. The kids are coming for Thanksgiving and we would like them to have a working TV in the guest bedroom.
Thank you
JUMP TO SOLUTION
@ userwbFZ6M9UhI I would be happy to investigate further. Can you please send a Private message here: https://bit.ly/2mQxylV with the correct serial number as the one that was provided is not coming up as valid in our system.
AdamTexas
JUMP TO SOLUTION
Yay worked!
Mark from Samsung helped me. All we did was to disconnect from the extension cord and plug in the Samsung tv directly to the wall plug. So it worked..
Tv with extention cord turns on and off since it receives low voltage.
Happy now!
