userIlc0pGj0s1
Re: Samsung LED Smart TV keeps turning off and on
JUMP TO SOLUTION
  • Wow so disgusted with this company right now. Mine just started this morning and after talking with customer service they keep saying that I need to buy a new remote. The only trouble shooting I have done was plug TV back in after it was unplugged for 20min. I try to tell them that the original remote is put away in drawer in other room and the universal has no batteries in it. So disappointed with this company. I have barely owned my 65in curved TV for a 1 -1/2 years. Getting more mad as I type this and watching my TV turn off and on repeatedly by itself.
userywGPpBAE7o
JUMP TO SOLUTION
I had the Power Supply Board replaced and it's about 1 year and so far so good...........
Samsung_kGErGL1
How are all the hunk up in the back of it
JUMP TO SOLUTION
userMs8SNa0AyZ
You need to replace tv tuner
JUMP TO SOLUTION
userjFTN73AnKH
JUMP TO SOLUTION
I’m having the same problem and would appreciate any help please. I have a 9 Series Curve TV and it constantly turns off and off by itself. I bought it about 2 years ago at Best Buy. I unplugged it from the wall outlet at both 10 minutes and another time for about 8 hours. It did not fix the problem. Can you please help me fix the problem? These are the specifics of the TV:
Model Code: UN65KS9500FXZA
Thank you in advance and I hope to hear from you soon.
JUMP TO SOLUTION
I see you have sent us a private message as well userjFTN73AnKH, I'll follow up with you there shortly. Smiley Happy
