rkou08
Samsung LED Smart TV keeps turning off and on
JUMP TO SOLUTION
The tv turns off every 20-25 mins
1 SOLUTION
userEniK85muBH
Do you have any devices connected using CEC? I noticed th...
JUMP TO SOLUTION
Do you have any devices connected using CEC? I noticed this would happen with an audio system I had connected to my TV. Mine is a Vizio though.
8 REPLIES 8
userF6yE8t6Vkl
Did you find a solution?
JUMP TO SOLUTION
rkou08
Re: Did you find a solution?
JUMP TO SOLUTION
My soundbar was connected to the CEC
useriBUym1jt4s
JUMP TO SOLUTION
Did anyone find a solution, my smart tv is doing this.
rkou08
JUMP TO SOLUTION
Turn off the Anynet CEC in the settings and it should work
userEniK85muBH
JUMP TO SOLUTION
Luddite4Help
Re: Do you have any devices connected using CEC? I noticed th...
JUMP TO SOLUTION
Did you fix the problem?
seelahi
JUMP TO SOLUTION
There is no fix for this problem, unless you check the power supply capacitors, in tv, there is small black button , which you push to turn ON and OFF, the tv, I am sure that switch is bad. Samsung not giving any fix may be issue with product liability.
user3D4lnATEH0
Re: Samsung LED Smart TV keeps turning off and on
JUMP TO SOLUTION
my tv was turning off and on randomly.  We turned off the "anynet"  and turned off the auto shutdown in the menu under smart hub or systems.  (He is grouchy now and pretending to be tired and cannot remember for sure) but I hope this will help someone.  Tv is working fine now.
