- Mute
11-09-2020 05:55 PM (Last edited 02-03-2021 07:49 AM by MsBri1 ) in
HD and UHD TVsWe have been having issues on our tv with the volume. When trying to move up or down its moves once and goes right back to what it was at. We have tried on the samsung, firestick and DirecTV remote with all having same issue. We have to reset tv numerous times for it to work. This happens daily and is very frustrating.
Solved! Go to Solution.
- Mute
12-15-2020 10:01 AM in
HD and UHD TVsCan you send me a private message with your full serial number? I would love to look into this further please. http://bit.ly/2tCGnGK
- Mute
12-29-2020 04:08 PM in
HD and UHD TVs- Mark as New
- Mute
12-29-2020 05:40 PM in
HD and UHD TVsI am sorry to hear about this. Please send the full model and serial numbers to this PM Link.
- Mute
01-19-2021 07:28 PM in
HD and UHD TVsI am having the same issues. Its so frustrating i dont think i will ever get another samsung tv. Has been goingnon for months. Tried reset smart hub. Turned off autorun. Nothing works. Keep changing apps and inputs.
- Mute
03-26-2021 08:30 AM in
HD and UHD TVsStarting last night, my TV randomly in the middle of viewing a program starting having an issue with the volume and this menu popping up on the screen. It would Open the Accessibility Menu, speak very fast and several On/Off items would flash. We closed the menu box and it would randomly open it up again after about 20 minutes. Then this morning, the volume would randomly mute itself. The menu would pop open and here we go again.
I took the batteries out of the remote. Didn't work. I rebooted the TV, disconnecting everything from it and reconnecting everything to it. Didn't work. I chatted with a Samsung Support person via online chat and while he tried, was little help. We reset the factory settings on the TV. Didn't work. I live in Roswell, GA and he gave me the number to the closest tech center in Ft Lauderdale, FL...500 miles away from me to seek help. Not amused!
Has anyone seen or heard of this happening? Is there anything I can do to fix it. I've tried updates, resetting, replacing batteries...everything. Do I just need a new remote or is the TV shot after 4.5 years?
I appreciate any and all feedback!! Thank you!
Frustrated in Georgia!
- Mute
01-29-2021 12:53 PM in
HD and UHD TVsHello There
Some reason at times, the TV volume gets stuck where it won't go up and down, usually resetting the sound or Resetting smart hub fixes it, any idea why this is happening? or a permentent fix?
- Mute
02-02-2021 12:33 PM (Last edited 02-02-2021 01:36 PM ) in
HD and UHD TVsI'm sorry to hear that, does this occur after factory resetting the TV?
- Mute
02-02-2021 01:36 PM in
HD and UHD TVsThat's great to hear please feel free to reach out if you have any questions!
- Mute
02-02-2021 01:23 PM in
HD and UHD TVsWell it was happening after a factory rest, i have since changed the HDMI Cable, and updated the Firmwire from Samsung support site download for it, so far haven't heard from family member that watch that set the most of any further issues with the volume thus far.
Hopefully i have solved it for good
- Mute
02-21-2021 05:34 AM in
HD and UHD TVsPlease share the solution.
