user9B8srePYrs
Samsung UE43NU7400 43" Smart 4K Ultra HD TV with HDR keeps dropping wifi connection.
JUMP TO SOLUTION
My Samsung UE43NU7400 43" Smart 4K Ultra HD TV with HDR
keeps dropping wifi connect. If I reset the the network it connects again with no problem. This is now on a daily basis. All software is up to date.
1 SOLUTION
Re: Samsung UE43NU7400 43" Smart 4K Ultra HD TV with HDR keeps dropping wifi connection.
JUMP TO SOLUTION
Regrettably support for non-US models is very limited. We suggest reaching out to a support team in your area for further assistance. You can do so by using the following link: https://www.samsung.com/us/common/visitcountrysite.html  Thanks!
2 REPLIES 2
JUMP TO SOLUTION
user9B8srePYrs
JUMP TO SOLUTION
Thank you, got through on the phone to Samsung in Uk and problems now sorted.
