userRPwQjLbPRB
Smart Remote ussage without Bluetooth capability
Hi,
I need to purchase a Samsung TV and I like NU 7100 or NU 7300. but both of these don't have built in Bluetooth. Does that mean I can't use smart remote control with it? Because the remote control out of box of NU 7100 is just disgusting.
Can anyone please guide me if I can use USB based Bluetooth receiver?
Or should I purchase 55KU7500 instead which has built-in Bluetooth support?
Can anyone compare 55NU7100 with 55KU7500 in terms of its features. I understand that KU is 2016 and NU is 2018 model.
But what is the difference between 7100 and 7500 models?
Thanks
1 REPLY 1
Re: Smart Remote ussage without Bluetooth capability
That is correct, without Bluetooth, the smart remote cannot pair and work.
You cannot use a USB based Bluetooth receiver to resolve this.
I would recommend purchasing a model with build in Bluetooth.
You can find the specs for the 55KU7500 here: Link
And the specs for the 55NU7100 here: Link
