- Mute
11-26-2017 06:02 PM (Last edited 08-24-2023 05:31 PM by SamsungCaleb ) in
4K, 8K and Other TVsHello,
I recently purchased a Samsung - 55" Class (54.6" Diag.) - LED - 2160p - Smart - 4K Ultra HD TV, and now that I have had it a few days, I am noticing that the sound pops every couple minutes or so. It makes no difference weather the volume is higher or lower it still pops, but the intensity of the pop does change with the volume. (Quiet pop/crackle when on a lower volume) is there anyone who could give me advice on what to do, or maybe someone has had the same problem and has solved it?
Solved! Go to Solution.
- Tags:
- 4k
- Mute
05-24-2018 01:57 PM in
4K, 8K and Other TVsGood news I hope Thanks
- Mute
05-28-2018 10:07 AM in
4K, 8K and Other TVsI was sent a pre-release firmware update to fix the popping bitstream audio bug: after 1 week NO popping !
- Mute
05-28-2018 10:12 AM in
4K, 8K and Other TVsCan you tell us your current firmware so we know what version to look out for? Still says 1210.8 for QN55Q7FAMFXZA currently on Samsung website.
- Mute
05-30-2018 08:40 AM in
4K, 8K and Other TVsMy friend and I have the same Samsung HDTCV Curve with Sound bar. the same is happening to us.
Please tell us what firmware will fix the issue.
- Mute
06-01-2018 07:07 AM in
4K, 8K and Other TVsApparently sometime in June a new firmware update will be released with the popping issue included pending the outcome of users testing the beta update.
- Mute
06-01-2018 12:06 PM in
4K, 8K and Other TVsSorry to hear that you have this popping noise. I have provided you with a link for this issue. Feel free to reach back out if you still need assistance.
- Mute
06-01-2018 01:32 PM in
4K, 8K and Other TVsMy set is wall mounted. Any specific guidance for this configuration? Model UN75MU800D software 1210.8
- Mute
06-01-2018 01:45 PM in
4K, 8K and Other TVsThis is a hardware / software issue, and how the set is mounted should have no impact on this issue, which seems to be a firmware issue.
I have posted that I solved my 'popping' by upgrading my HDMI cable, but many do not seem to take it to heart, and are continuing to pound Samsung for something more.
Have a nice weekend.
- Mute
06-01-2018 01:59 PM in
4K, 8K and Other TVsWas this cable used between the back of the set and smartconnect hub as well as between the hub and peripherals?
- Mute
06-01-2018 02:12 PM in
4K, 8K and Other TVsI upgraded the HDMI between my DVR and the OneConnect / Smart hub. The hub has a specialized single cable between the hub and the unit.
