- Mute
11-26-2017 06:02 PM (Last edited 08-24-2023 05:31 PM by SamsungCaleb ) in
4K, 8K and Other TVsHello,
I recently purchased a Samsung - 55" Class (54.6" Diag.) - LED - 2160p - Smart - 4K Ultra HD TV, and now that I have had it a few days, I am noticing that the sound pops every couple minutes or so. It makes no difference weather the volume is higher or lower it still pops, but the intensity of the pop does change with the volume. (Quiet pop/crackle when on a lower volume) is there anyone who could give me advice on what to do, or maybe someone has had the same problem and has solved it?
Solved! Go to Solution.
- Tags:
- 4k
- Mute
07-03-2018 07:29 AM in
4K, 8K and Other TVsModel Code #: UN55MU6290FXZA
- Mute
07-04-2018 03:47 AM in
@SamsungCat wrote:Please provide me with your complete model code.
I'm trying not worry about it. It seems to happen in HDR only, meaning the backlight is maxed, combined with the extremely hot weather, I am leaning towards this combination being the cause.
2018 Q7FN.
- Mute
07-04-2018 09:27 AM in
Heard the "popping" sound again this morning, was watching a HD channel.
What you're saying makes sense, but sad to say, the sound is still happening which means the new version update isn't working, which means to me that there is a defect with the TV or one of its components.
Next step? Back to Samsung customer service; not looking forward to that interaction.
Thanks, Joe
- Mute
07-04-2018 09:52 AM in
4K, 8K and Other TVsNot sure what software version your tv is on my popping sound was solved with firmware version 1230 with 2017 QLED.
- Mute
07-04-2018 09:56 AM in
4K, 8K and Other TVsVersion 1230
- Mute
07-04-2018 10:03 AM in
4K, 8K and Other TVsHopefully a Samsung engineer will read your post and contact you.
- Mute
07-04-2018 10:10 AM in
4K, 8K and Other TVsFingers crossed....
Have a good 4th!
- Mute
07-06-2018 05:00 AM in
4K, 8K and Other TVsI have the un75mu6300 with the pop and lowered volume. My version is 1210.8 and it won't update. Says it is the current version.
- Mute
07-06-2018 02:54 PM in
4K, 8K and Other TVs1230 is available on our website if you'd like to update over USB. You can find the site for the download here: https://www.samsung.com/us/support/owners/product/2017-uhd-smart-tv-mu6300
- Mute
07-06-2018 08:29 PM in
4K, 8K and Other TVsDid you look up your model # on the Samsung site; it'll tell you what's out there for ur set.
