Highlighted
UE65KS9000 Smart Remote not working
JUMP TO SOLUTION
Hello,
I have the UE65KS9000 TV and the remote control stoped responding for certain buttons,
I contacted Samsung and they said they can replace it for a price tag of 90 euro but this specific remote control is not very qualitative since my friend who bought the same TV has the exact same issue.
Can i use a better or later generation remote for this tv?
Thank you!
1 SOLUTION
Highlighted
Honored Contributor
Re: UE65KS9000 Smart Remote not working
JUMP TO SOLUTION
Thanks for reaching out. This forum is for support of US products and customers. As your product is a non-US model and support for these models is very limited, please seek a support team for your area. You can do so by using this link: https://eu.community.samsung.com/
1 REPLY 1
Highlighted
Honored Contributor
JUMP TO SOLUTION
