- Mute
04-18-2021 07:44 PM in
4K, 8K and Other TVsWe started noticing some bright and dark spots on our TV and the past week noticed some very hot spots on the bottom right corner area. It’s almost hot enough that I’m starting to worry about it causing a fire or melting. I’ve read about several others with similar issues and even some class action suits? Is there a fix for this or is replacing it the best option?
Solved! Go to Solution.
- Mute
04-19-2021 07:07 AM in
4K, 8K and Other TVsI recommend letting a service technician have a look. As we would like to gather additional information and look at this from a case-by-case basis please provide the full model code and the serial number of the device as well as your best contact phone number, name, and email.
Send a message on Facebook
Send Message on Twitter
Send Message to Moderator
- Mute
- Mute
4K, 8K and Other TVsAn Accepted Solution has been marked and provided for this thread. The thread will now be locked for further replies. in hopes to keep the integrity of the thread from steering in a non-technical manner. If you have a separate concern, feel free to post again or send one of our moderators a private message with more details. Please note duplicate posts on similar subjects starting 2/1/21, will be removed to keep our community organized and make it easier for our users to find resolutions and needed content. Remember that if you do make a post, please include as many details about your symptoms as possible. Also, make sure that your title is a good summary of the overall situation that's occurring with your product. Thank you for being part of the community!
