Highlighted
UN75RU7100FXZA 4K UHD and Fire TV Stick 4k
I purchased the UN75RU7100FXZA 4K UHD last May 2019 and I recently purchased the Fire TV Stick 4K. Fire Stick mentions needing a HDCP 2.2 connection. I cannot find mention of that HDMI HDCP 2.2 connection in the specs.
I have also tried to put the Fire Stick in HDMI port 1 and 2. Port 1 will not show anything in 4K and I can see Port 2 trying to get the 4k resolution in the upper left hand corner, but again it does not work and no picture.
Are these ports HDCP 2.2 compatible? I assume they would be as this TV is a very recent purchase and HDCP 2.2. has been around for a while already. Please confirm or let me know what to do to get the 4K Fire Stick working in 4K
3 REPLIES 3
Highlighted
Re: UN75RU7100FXZA 4K UHD and Fire TV Stick 4k
Good afternoon. The television does support HDCP 2.2.
Highlighted
that blows
Highlighted
any adapter available or firmware update?
