Highlighted
Vertical lines on TV LED 7100 series
vertical lines on 7100 series, model UN60ES 7100
4 REPLIES 4
Highlighted
Re: Vertical lines on TV LED 7100 series
We're sorry to see that. Does this issue occur on all sources and inputs? Have you tried unplugging the power for 5 minutes or trying different HDMI cables?
Highlighted
I tried on other sources with a different  cable, and unplugged my TV,  no change, lines are still there, next I will take the back panel off and check all connections inside
Highlighted
it's also intermittent, now they disappear,  I am sure they will be back as before
Highlighted
The next step would be to proceed with service. You can use the following link below to request service or contact our phone support line at 1-800-Samsung to have service set up for you:
https://www.samsung.com/us/support/service/
