Wi-Fi connect problem
(Topic created: 07-19-2021 06:35 AM)
dlpg47
Cosmic Ray
4K, 8K and Other TVs
Model: UN55TU8000FXZA  Current s/w version: 1460
As has been reported by others wi-fi connection fails after powering off TV.  To enable, the current "fix" is to hold power button down until the Tizen screen appears then its OK until power down, then repeat "fix".
No wi-fi problems with any other devices, except the TV.
Months ago I read that Samsung is aware of the problem and a fix is coming soon.  Can we get an update on when the fix will become available.
SamsungJam
Here's a link to the update: https://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=US&CttFileID=7983794&CD...  make sure that you have a USB with at least 8GB of free space on the flash drive (or 12GB total if the zip file is also on the flash drive).  We apologize for any inconvenience's that this may have caused.
SamsungJam
dlpg47
Cosmic Ray
Thanks but why isn't this update available OTA? Customers may not want or know how to deal with this method.
SamsungJam
OTA would send it to every television and it's only certain models that are doing it so the update is only available through the USB method.  If you are needing assistance setting that up, here are the steps to get you up and running with the update.
dlpg47
Cosmic Ray
Nudge on the f/w update question.
dlpg47
Cosmic Ray
Today I downloaded the latest f/w for my TV -- v2016.1 dated 7/8/2021.
Are updates cumulative? In other words, does this update contain the "fix" for the wi-fi problem or was that a "special" update of some sort.
Will not update until I hear back.
dlpg47
Cosmic Ray
After a failed attempt to update via USB, the second try seemed to work.  Software is now at 1469.1 from initial 1460.  Wi-fi "held" after power cycle.
Hope this takes care of the problem, but I feel for others who suffer from this and have no idea this community exists or are not capable of doing this update themselves.
Guess I'll check the Samsung Download Center from time to time to check for updates that might not be available OTA.
dlpg47
Cosmic Ray
For grins, I just checked the Samsung Download Center for my model TV and found a newer version of firmware that was dated 7/8/2021.  Does this newer version include the wi-fi fix plus other stuff?
dlpg47
Cosmic Ray
Oh and why isn't the above f/w update available OTA ?  What's the purpose of OTA if updates are really not available using that method?
