Won't turn on after power outage
(Topic created on: 4/30/21 10:59 AM)
userTRYoxduzRb
4k, 8k and Other TVs
UN55MU7500FXZA  OCT 2017
After a brief power outage (10 seconds) TV won't turn on. We have had outages before and had no problems.
Any suggestions, thanks Mark.
SamsungAl
This is going to require service as the troubleshooting steps didn't work. You can use the following link to locate a service center near you: https://www.samsung.com/us/support/service/locations/
SamsungAl
Have you tried plugging the TV into a wall outlet or a surge protector different from where it's plugged into now?
userTRYoxduzRb
Yes, I did. Same result.
SamsungAl
