- Mute
- Email to a Friend
12-19-2020 07:49 PM in
4k, 8k and Other TVsI have a UN50TU8000FXZA hooked up via the optical cable to a Yamaha A-S301 Integrated amplifier. Every 5-to-20 minutes we get a prompt that says "setting up to adjust speaker volume with smart remote". This mutes the Yamaha and we then have to choose to cancel or go to a setup menu, which stops whatever we're watching. At the setup menu we are prompted to select the brand of the output device (Yamaha), then the TV performs a test that switches the Yamaha off. Then we have to turn the Yamaha back on, go back to whatever app we were using and navigate to whatever program we were watching. The whole process repeats at random every 5 to 20 minutes. Anyone know of a workaround to disable the prompts?
Thanks!
- Mute
- Email to a Friend
01-15-2021 08:02 AM (Last edited 01-15-2021 08:03 AM ) in
4k, 8k and Other TVsI have the same exact issue! I have a QN85Q6DTAFXZA. How annoying. Any resolution to this issue?
- Mute
- Email to a Friend
01-29-2021 09:13 PM in
4k, 8k and Other TVsSo far no fix. Bumping this up. It seems to be getting worse.
- Mute
- Email to a Friend
a month ago in
4k, 8k and Other TVsDo any of your other settings reset? Have you set up the television with SmartThings?
