un6900 with bluetooth usb device won't connect to keyboard
(Topic created: 06-23-2021 01:14 PM)
userzBD0QFlIQK
4k, 8k and Other TVs
 have a UN65NU6900FXZA, works great, but doesn't support Bluetooth. I found this out when I tried to connect a Bluetooth keyboard. I connected a keyboard to the USB port to see the TV would see the keyboard, that worked but was very inconvenient to use.
Looking at the settings options on the TV there was no choice to connect to a Bluetooth device, so I then tried a USB Bluetooth device for a PC in the USB port on the TV and that didn't work.
I called Samsung support, they gave me a link to an Amazon page that contained several USB Bluetooth adapters and said any of them would work. I bought an adapter that supports RX an TX, plugged that in and no connect to the keyboard.
So I would like to know if anyone has connected a Bluetooth keyboard to a USB Bluetooth adapter on this model of TV and how they did it?
The keyboard I have is a Logitech k480, the adapter is a Display Bluetooth Adapter, model K15 which supports RX/TX, is driver free has a LCD showing connection status.
Any help would be greatly appreciated.
SamsungJam
The adapter would need to be HID compliant to work with the television.  We apologize for any inconvenient that this may have caused.
userzBD0QFlIQK
Do you have any recommendations?
