- Mute
ā05-06-2025 02:21 PM in
A Series & Other MobileFor some reason the background blur on the quick panel won't respect the settings made on Home Up app and ThemePark, so it has a stuck level of blur and can't be colored into something dark as a sunglass (with blur enabled). And disabling all transparency makes the quick panel opaque no matter how I try to set its transparency values on ThemePark. I've tried everything, but One UI 6.1 is bugged on this. One UI 7 has fixed it on another phone (A56), mine is A55.
Also, I would like to set the black color value to be lower on A55, because its blacks don't match the black borders on the screen, like the old S10 Lite used to.
One last thing is, why can't Samsung keyboard use auto space after commas (, ) and periods (. ) on Brazilian Portuguese language?
This auto space feature only works on pressed predicted words.
