Battery will not charge
(Topic created: Tuesday)
Clover312
A Series & Other Mobile
I'm wondering why my battery won't charge. It's SM- A166U . I have it plugged in now as I am using it and it keeps losing power. Does anyone have this problem? If so what can I do?
Oxford
Honored Contributor
Have you tried cleaning out your usb-c port to make sure it's making good contact when you plug it in?
GaryB82
Galactic Samsung Care Ambassador
Hello @Clover312 ,
At the bottom of the members app, I suggest clicking on the support tab and running the diagnostic tests to check the battery and see if any issues arise. Additionally, I recommend trying a different power brick and cable to ensure that the brick is functioning correctly and is providing sufficient power to charge your device.
If you've found my post to be helpful, Please like my Comments āœ“āœ“āœ“.
If my response resolved your issue, please press the Like and āœ“āœ“āœ“ to Accept as Solution button.
LongHiker
@Clover312 The usual culprits are bad cable, bad charging adapter, damaged USB port, or failed battery.
Have you tried changing the cable and the charging adapter?
Jamess467
Supernova
I would try different cables, but be sure, not all USB c cables are the same. And if still has an issue try a different brick, if the problem persist, I would take it to a Samsung store for further assistance. Than there is a diagnostic section on this app that can assist in diagnosing the issue.
3Fees
Supernova
Run a test on the battery on the support page.
Cheers
3Fees
