Problem with A05s Charging
(Topic created: 02-25-2025 01:16 PM)
Neme1
A Series & Other Mobile
I recently bought an A05s 4G, and I used it for a couple of days, but I ran into a little problem. My phone shutdown after the battery reached to 0. I put the phone to its own charger 10 minutes later, as I came back home, and It vibrated, not showing anything on display. I let it for Two hours, and I checked it afterwards. Still not powering on, still vibrating after charging. I had battery drainage before on other devices, and even on Samsung ones, but this time, it didn't want to turn on at all. I tried a soft reset, I tried to hold the power button, still no answer. Is it a hardware-related problem or a software-related one? How can I solve it?
Thank you.
GaryB82
Galactic Samsung Care Ambassador
Sounds like the battery died if it’s still within the return window I’d suggest returning it if not you have a few options.
1. Contact Samsung support for warranty
2. Contact a repair center and have it checked out
3. Contact your Carrier if you have insurance on your device
https://www.samsung.com/us/support/contact/
https://www.samsung.com/us/support/service/locations/
If you've found my post to be helpful, Please like my Comments āœ“āœ“āœ“.
If my response resolved your issue, please press the Like and āœ“āœ“āœ“ to Accept as Solution button.
3Fees
Black Hole
Never let your battery go to zero, the battery is deeply discharged and needs a boost to get charging again if the battery is still good. You can try a different charger and cable otherwise you'll need a service center to check the battery and get it going or replace the battery.
Cheers
3Fees
louismutiba
I bought mine and used it for only 2 months, and it stopped charging,  returned it to Samsung, and it was fixed, now after 4 months same problem resurfaced again. Is it a common problem with this model or it's just my fone?
