Wi-Fi health problem connection
(Topic created: 03-10-2026 05:51 PM)
A Series & Other Mobile
lately I've been having a vomiting sensation without any reason, as I'm sitting I feel as if I'm going to vomit and nothing comes out, then I noticed, as I'm sitting in my recliner I'm holding my cell phone against my stomach and using Wi-Fi for internet search, "The idea dawned on me" that the Wi-Fi might be causing the problem , I purchased a USB 3.0 USB C RJ45 LAN Gigabit Ethernet Adapter External 10/100/1000Mbps Interface Network adapter from AliExpress. I noticed that my vomiting sensation have eased, The problem with this specific adapter that it does not have a power supply therefore the phone will die then I have to recharge it to use it again, I found on AliExpress a different device, a Connection Mobile Phone Adapter lightning to RJ45 Port Ethernet Converter PD Charging Network Cara USB C adapter. And it worked fine with my Samsung Galaxy A54, yet it does not want to work with my Samsung Galaxy A36, I keep getting the message , check your charger connection, Make sure the cable and charger are properly connected. If this as happens frequently, try replacing the charging cable, I am using a new cable with the charger, and the other cable from the charger to the adapter is fine, I've been using it to charge my phone without any problems, I am not sure if the low voltage charging message is preventing me from using the adapter with my A36 or is it a question of settings, I tried to look around on the internet and in my phone I wasn't able to find anything, if you have a solution to this problem please provide it.. thank you
