After the update my touch screen will not work unless I use the Spen. Samsung made a comment blaming it on Google?? But I've heard from other... View Post
Why did they update this? Who asked for them to change the navigation bar gesture settings? Before you could just swipe up for the navigation bar... View Post
Such bs, they changed the three swipe up buttons (open apps, home and back bottons) wich were invisi... View Post
They heard you, Samsung has brought back the ability to hide your Navigation Bar and Swipe Gestures. Â You will have to download Goodlock and... View Post
Thank you for this post, the newest update has really messed with me causing me to miss hit alot of ... View Post
The Galaxy S24 series has arrived, sporting a familiar yet subtly tweaked design now with its almost flat display. Samsung has opted for refinement... View Post
Thank you for your reply. I also noticed the bottom speaker not that good, but I have a case on mine... View Post
The answer is unfortunately not set in stone, and will vary from not only model to model, but carrier to carrier. Updates are slowly released by the... View Post
ONE UI 6.0 Samsung has started to roll out One UI 6.0 for the S23 Family and the update will start r... View Post
Purchased new, I thought, out of the box Samsung Galaxy A15 5G- also got a new wall charger accessory- which was the problem after 1yr - Charger wall... View Post
I've had this watch less than a month. I have followed the available advice, turned down brightness and updates but it still constantly overheats.... View Post
Bring back the old object eraser the new one is horrible. I will no longer purchase Samsung phones until it gets fixed . View Post
My email icon appears twice on android home screen. I can't move either one to another screen, or delete either one. I moved my RING icon but... View Post
Sync setting options are not the same both both email accounts. One allows me to select the folders, the other does not. View Post
I have tried and tried to delete tags that I no longer needed in Samsung Notes. That I just do not want anymore. And I cannot figure out for the life... View Post
Hi,After the 6.1 update all the Calendar notifications show my Email address instead if the notification itself.So I have to expend it everytime to... View Post
How can I turn off or somehow get rid of this annoying program? View Post
