After the update my touch screen will not work unless I use the Spen. Samsung made a comment blaming it on Google?? But I've heard from other... View Post
Why did they update this? Who asked for them to change the navigation bar gesture settings? Before you could just swipe up for the navigation bar... View Post
Such bs, they changed the three swipe up buttons (open apps, home and back bottons) wich were invisi... View Post
Every since updating to this verson, The most significant features i use are circle to search and the lockscreen widgets. Some bugs: slow charging... View Post
I'm experiencing this too. I use free form stickers for my interior design projects. This clip chang... View Post
They heard you, Samsung has brought back the ability to hide your Navigation Bar and Swipe Gestures. Â You will have to download Goodlock and... View Post
Thank you for this post, the newest update has really messed with me causing me to miss hit alot of ... View Post
The Galaxy S24 series has arrived, sporting a familiar yet subtly tweaked design now with its almost flat display. Samsung has opted for refinement... View Post
Thank you for your reply. I also noticed the bottom speaker not that good, but I have a case on mine... View Post
The answer is unfortunately not set in stone, and will vary from not only model to model, but carrier to carrier. Updates are slowly released by the... View Post
ONE UI 6.0 Samsung has started to roll out One UI 6.0 for the S23 Family and the update will start r... View Post
Samsung is pleased to announce an important software update for Samsung gaming monitors. Â The software update supports the following Samsung... View Post
It happens frequently that an invitation from gmail or outlook sent to my Microsoft 365 account is not processed correctly with the Samsung Email... View Post
Bring back the option to adjust notification sounds per app! It may be referred to as notification channels. Either way, it's absolutely... View Post
You absolutely can first you need to go to Settings > Notifications > Advanced Settings > toggle on ... View Post
I have a note 20 for several years and am using the same sim card with the same company also for several years. Several days ago my data service... View Post
If you're Book Cover Keyboard disconnects for 2-3 seconds. It disconnects and stops typing and/or repeat the last input (aaaaaaa. Like that). It... View Post
I love Secure folder and In Oneui 4 it used to have support for Secure folder but after Oneui 5 it didn't anymore and that really sucks View Post
My Galaxy watch 4 classic has an issue. When I go into the app screen and rotate down it works smoothly. But when i rotate it back up. It glitches and... View Post
