Battery Percentage scaling when Battery Protect is enabled.
(Topic created: 01-22-2022 11:54 AM)
Gr8MightyDaddy
Android 12
So I have a Tab A7 Lite and S21.  I have Battery Protect enabled on both devices.  This feature causes the battery to charge to 85% of capacity.  On the Tab A7 Lite, the tablet scales the battery percentage indicator so that when it shows 100% charge, it is really at 85%.  The S21 though, chargers to 85% and shows 85%.  I know it's psychological, but I wish Samsung would update the S21 to also show 100% when the battery is at 85% charge like the Tab A7 Lite does when Battery Protect is enabled.
bill-e
Samsung Care Ambassador
Android 12
I understand your desire but I personally like it staying at 85%.  I switch between protect on/off depending on my intended usage scenario and knowing at a glance that I'm on the shorter duration 85% charge is useful.
** If my response helps, please click on Like (Heart). If I resolved your issue also please click on Accept as a Solution so that others can benefit.
Bill
Galaxy S21 Ultra 512g(VZW), Galaxy Book (original, VZW), Tab S8 Ultra, Tab S4, Galaxy Watch3 (VZW)
Android 12
It would be nice to have this as a option.
CROSSCOWBOY
Android 12
After the last update the screen is all over the place e very time I go to touch it the screen goes back to the home screen
LindaK20
Galaxy
Android 12
I believe it has to do with Android 11 on the tablet and Android 12 on the phone. I have the same situation between my Tab S6 and Note 20 Ultra. The phone was updated to Android 12 before I tried the battery protect feature, and the tablet won't be updated until May. The Tab A7 Lite is scheduled for June.
