userT5PLTUS5fJ
Problem with Chromebook 3 wont turn on
I have a Chromebook that won't turn on but as soon as I insert the charger cable it flashes green and orange. Please help all I did was turn it on close the lid then it went dead this is the first signs of life in two weeks. Now the flickering lights when I insert the charger.
3 REPLIES 3
Re: Problem with Chromebook 3 wont turn on
We are sorry to hear about this. Please send the model and serial numbers to this PM Link.
useraxDv3j9roA
I haven't had that issue with my samsung Chromebook 3 but I did just recently updated it and now blue tooth won't work
@useraxDv3j9roA Have you tried a powerwash of the device?
