Galaxy Pro 360 Battery Replacement
(Topic created: 10-09-2021 03:30 PM)
userCnabNjldLp
Computers
Is the battery on the Galaxy Pro 360 replaceable?
MsBri1
Neutron Star
Computers
Hello there,I do apologize for the confusion so it appears I was incorrect the batteries are replaceable items and I would encourage you to download and review the manual here Download Center if needed.
MsBri1
Neutron Star
Computers
Hello, I apologize for any inconvenience however no the battery would not be replaceable as this computer is equipped with an internal battery.
userCnabNjldLp
Computers
All laptops are equipped with an internal battery.
My Asus has 6 screws, take the cover off, swap the quick connect battery, done.  It appears Samsung is more of a mind like Apple, that the customer does not have a right to repair the device they bought.
MsBri1
Neutron Star
Computers
userCnabNjldLp
Computers
The manual says it must be taken into a Samsung service center, at customer expense.  Probably $200, $250 I'm guessing?  Maybe more.
So much easier to just put screws in the case and a quick connect connector like your competitors do.   I have a battery for my Asus arriving this week, $42
