Highlighted
Galaxy Buds sound delay
My Galaxy buds have around a .5 to 1 second delay, to any device (s8 phone and windows laptop).  They are updated and i can't seem to find a fix for this. Its really frustrating as i got them so i can walk around and watch movies etc but cannot do this as the sound doesnt match with the pictures. Any Suggestion?
2 REPLIES 2
Highlighted
Re: Galaxy Buds sound delay
Hey there!
Thanks for reaching out for assistance.
Have you already tried clearing the cache of your wearables application?
Highlighted
Comet
I recommend disconnecting your earbuds from your device through the bluetooth settings. Once you do that, uninstall the Galaxy wear app. Restart your phone. Reinstall the Galaxy wear app. Reconnect your earbuds. Then update if needed. This should do the trick👍
If you've found my post to be helpful, please like the post. If my response resolved your issue, please press the "✓ Accept as Solution" button.
