Showing results forย
Search instead forย
Did you mean:ย
Battery and Device Care
(Topic created: 06-08-2023 10:38 AM)
DaleNet
Nebula
Discussions
On the Galaxy Wear app for my Watch 4, the Battery and Device Care does not display any data.  When selected, all it does is say CHECKING and then says RETRY.  On the watch, when selected, it does display data.
USBetaModerator2
Beta Moderator
Discussions
Hello ,
Thank you for your feedback.
Please submit an error report  through the Samsung Members or Galaxy Wearable app on your device:
- To provide feedback or to report bugs or errors in the Beta software, select "Contact us > Error reports" in the Galaxy Wearable app.
We apologize for the inconvenience and appreciate your contribution to the beta program.
Regards,
One UI Beta Team
DaleNet
Nebula
Discussions
There is no error.  I am on the latest Galaxy Wearable app for the Watch 4.  All the other function between the wearable app and the watch work fine.  It is only the the battery and device care that does not work.
DaleNet
Nebula
Discussions
Error report sent.  I cannot load the Galaxy Wearable app from the beta notice.  It says I am not authorized or  the test period has expired.  Checking my current app, it says I am on the latest version.
DaleNet
Nebula
Discussions
OK, I now have this issue resolved.  I was finally able to load the beta for the Galaxy Wearable app and now the app does show the watch battery and device care data.
userfbJuDoBvvQ
Discussions
Can't access battery information in the wearable app !!!!
ChaosSaber
Honored Contributor
Discussions
Install the manager beta app
ChaosSaber
Honored Contributor
Discussions
