Showing results forĀ
Search instead forĀ
Did you mean:Ā
Battery drain is still higher in Beta 2
(Topic created: 12-17-2024 04:12 AM)
AlienX
Nebula
Discussions
1. Standby battery drain has doubled. It used to be 0.4-0.5% per hr now 1% per hr.
2. During normal usage, battery drain also increased by 1.5 times. I used to get 9 hr SOT and with same apps I get only 6 hrs.
PS: Yes I have cleared cache, even power saving mode is not helping.
Discussions
Im not having a battery drain issue. S24 Ultra. 1734440283408.jpg1734485292855.jpg
AlienX
Nebula
Discussions
Lol... how would your battery drain if you leave it plugged? šŸ¤¦ā€:male_sign:
Discussions
I dont, that was from a full charge, here's what it is now 12 hrs later. šŸ––šŸ»1734485224058.jpg
AlienX
Nebula
Discussions
You literally unplugged your charger just little before taking the screenshot. So yes, it was plugged overnight.
Discussions
Comparing the two i provided, youll see that the projected consumption is very similar, again, not having battery issues.
AlienX
Nebula
Discussions
Your both screenshots are useless. 1st screenshot is supposed to tell standby battery drain but it doesn't since it was plugged overnight.
2nd screenshot is supposed to tell how much SOT vs. drain, which also it doesn't tell.
RaulitoElLobito
Cosmic Ray
Discussions
Noticed this too
retrofred
Halo
Discussions
I noticed that too. Still not bad considering this is still in the early beta stage.
AlienX
Nebula
Discussions
Yeh, let's see if it gets fixed by stable release.
